Exponent Decimal Places
ptc-3141073
In my results, if I have in^2, the 2 always shows up with the same amount of decimal places as the actual in^2 value instead of just showing up as 2. ie it shows up as 1.25in^2.00 instead of 1.25in^2. Is there a setting I'm missing? I'm using Mathcad 12.
RichardJ
(To:ptc-3141073)
It's a bug. I don't recall when it was fixed. If you are running 12.0 then you should download and install 12.1. That fixes a lot of bugs, but I'm not sure about that one. Richard
Thank you for the response. I'll see if the download works.
