Please let me know if MathCad 15 has the same capability as previous versions to change the cursor to a flashing light-bulb when calculating.
Thanks.
Anousheh
Unfortunately not but you can proceed with your work when the program is calculating. This was not possible in for example MC11. Although I have to admit I also miss the bulb...
Filip
Filip
Thank you Desomer.
Now, I know that I am not looking for the bulb!!!
Anousheh
When you hit recalculate you will see a green border around the region/area being calculated
Mike
But only if the region being calculated is on your visible bit of screen
Philip
But only if the region being calculated is on your visible bit of screen .
Philip
Well pointed out Philip ![]()
Mike
