FLASHING LIGHT-BULB !
Anousheh
Please let me know if MathCad 15 has the same capability as previous versions to change the cursor to a flashing light-bulb when calculating.
Thanks.
Anousheh
FDS
(To:Anousheh)
Unfortunately not but you can proceed with your work when the program is calculating. This was not possible in for example MC11. Although I have to admit I also miss the bulb...
Filip
5 REPLIES 5
FDS
(To:Anousheh)
Filip
Anousheh
(To:FDS)
Thank you Desomer.
Now, I know that I am not looking for the bulb!!!
Anousheh
When you hit recalculate you will see a green border around the region/area being calculated
Mike
But only if the region being calculated is on your visible bit of screen .
Philip
Philip
Well pointed out Philip
Mike
