File Type Error MathCad Prime 3.1
agent
Good Morning Community,
I have having a hiccup here with a file I have put a substantial bit of work into.  The file has been working fine for weeks including this morning however now I am getting an error listed:
The file type is not supported.
Log is located at
C:\ProgramData\PTC\Matchcad Prime\Logs\MathcadPrime_Exception_20151208_095225.log
Can anyone please assist me in recovering this file?  I have a backup saved from yesterday but I'd hate to reverse almost a full man day of work!
Thanks so much,
--Adam
12 REPLIES 12
(To:agent)
The file you attched, ETYP-0080.mcdx, is only containing  a number of zero bytes. So its useless - there is no information in that file which can be recovered.
As Prime does not offer facilities like Autosave as we are used frome Mathcad15 and below,, you will have to resort to a backup you made yourself.
WE
RichardJ
(To:agent)
Looking at it in Notepad++, your file consists entirely of NUL and NUI characters (I'm not even sure what the latter are) and, as far as I can tell, nothing else. There's more than 13 million of them, all on one line. So there's nothing in there to recover.
trussell
(To:agent)
i too am having trouble with a " file type not supported" message. I was using the file 3 days ago no problem, now theirs a problem.@
I've seen others posting the file up and having it fixed, can someone please give me a hand?
RichardJ
(To:trussell)
Please attach the file.
my cell phone shows i had attached the file but here on my computer it doesn't show. i cant seem to find any way to attach it again either! how do i attach a file to this blog?
RichardJ
(To:trussell)
At the top right of the edit dialog it says "Use Advanced Editor". Click on that, and you will get a new edit dialog where you can attach files.
You will not see this if you reply directly from your inbox; you need to go to the discussion thread and reply from there.
im sorry i missed that hyperlink. i was to focused on the actual dialog box. attached is the file I'm having issues with. thank you for responding quickly and for giving me a hand.
the file is also attached to my first post
LucMeekes
(To:trussell)
Nope, that's the log file (twice). There's nothing to recover from that file.
Attach the 'Mathcad_Program_Gearbox.mcdx' file that you had problems with loading if you want to have at least a chance of recovering...
sorry, reading other forums i was under the impression that the log is what was needed to solve the problem. no pun intended.
Hi Thomas,
- Sorry, but there's no content in the file.
This is all that NotePad++ can see
Regards
Andy
(To:trussell)
Sorry - the file you sent consists only of NUL bytes. There is no information there which could be recovered.
