Can someone please convert this worksheet o a version readable in Mathcad 14? Wrote it using Mathcad 15 but now have access only to Mathcad 14. Thanks a lot for the help.
Raja
Normally there should be no problem reading a MC15 file into MC14 as there are only marginal differences. Be careful to check if you have the most recent update for MC14 (M020 (single user), M030 (license user)). Most users of this forum suggest NOT to install M035.
Success
Success
Thanks. The problem was more of vista updates messing up M14. I can open the file.
Raja
