File save location
jdesai-2
File save location
In MC prime, how do you change the default location where the files are saved with the save as command? I don't want to keep updating every time I use save as.
15 REPLIES 15
LucMeekes
(To:jdesai-2)
My experience is that Prime (4.0) remembers where it last saved a sheet file and uses that as the proposed location for saving a new sheet file. Or am I being misled?
jdesai-2
(To:LucMeekes)
No way.
It keeps going to some arcane location each time
MJG
18-Opal
18-Opal
(To:jdesai-2)
I agree with Luc.
Here are my steps:
  1. Create new Mathcad Prime document (I'm using Prime 3.1).
  2. Save new document to folder XYZ.
  3. Close Mathcad.
  4. Open Mathcad.
  5. Create new document.
  6. Click "Save" or "Save As"
  7. The "Save As" dialog box comes up with folder XYZ open.
jdesai-2
(To:MJG)
absolutely not!
it goes back to the "arcane location"
MJG
18-Opal
18-Opal
(To:jdesai-2)
You might consider reinstalling Mathcad to see if that helps.  Beyond that, I'm not sure what would be causing your observed behavior.
VladimirN
(To:jdesai-2)
What version of Mathcad Prime are you using?
jdesai-2
(To:VladimirN)
PTC Mathcad Prime 3.0
(To:jdesai-2)
I have Prime 3.0 installed here, too, and can confirm, that Prime remembers the location where the last file was saved. Also, after closing the program and reopening it later.
But I don't know where Prime remembers this setting (registry, config file). Usually such user settings should be place where the user has write access. But its Prime by PTC, so we cannot be sure if such intelligent behaviour is implememted. Chances are that you have too limited rights at the place where Prime stores those settings.
jdesai-2
(To:Werner_E)
Thanks VladimirN. You may be ontosomething here.
My config file points to my Tempplates. What should it point to?
C:\Users\CurrentUser\AppData\Local\PTC\MathcadPrime\My Templates.
I found some of my old saves there. How do I make it save or save as to the location of the original file?
MJG
18-Opal
18-Opal
(To:jdesai-2)
Good find, Vladimir!
jdesai,
Look for the setting named "CWD" (Current Working Directory).  Whatever you set as a value for this setting should be where Prime defaults to save your next worksheet.
Try changing this setting to be something like "C:\Users\<your username>\Desktop" (without the quotes).  Then see what comes up in the save-as dialog.  It works for me.
As noted, however, Prime should be updating this setting each time you save a file.
jdesai-2
(To:jdesai-2)
what is
MathcadPrime.exe_Url_ehru2dx4wl1fcsqxso5q04rbyc5vkgpe
should I look for current folder in there?
MJG
18-Opal
18-Opal
(To:jdesai-2)
If you're referring to the location of the config file, mine is located where Vladimir noted except it has a bunch of extra characters, as you;ve noted.
If you navigate to C:\Users\<your username>\AppData\Local\PTC
There should be one or more folders.  One of the folders should be MathcadPrime.exe_<a bunch of characters>
Inside that folder is another folder with numeric digits and decimal separator.  Inside that folder is a file named user.config.  Open this file with a text editor and adjust the value for "CWD"
VladimirN
(To:MJG)
That's right.
VladimirN
(To:jdesai-2)
Check your config file, which is located on the following path: C:\Users\CurrentUser\AppData\Local\PTC\MathcadPrime\
LucMeekes
(To:jdesai-2)
OK, I use Prime Express, so in my case I am missing some features.
Did you check the OPTIONS pane that shows after you click the 'PTC MATHCAD BUTTON' at the top left corner of the Prime window?
