Find Function and an Array
I have two arrays I want to use with a find function. I'm having difficulty getting it to work. Any easy advice? See the clip of the spreadsheet below. The arrays are "t" for plate thickness and "a" for the plate radius. As you can see the definition is just passing through the find function. This is a Roarks workbook copied and pasted into a spreadsheet - Table 24A case 3. Thanks for any assistance. This is M'cad 15.
