To all
trying to remember my school days and the use of derivative (if that's the tool to use). Given the following
an X,Y,Z Cartesian co-ordinate system
a vector v with components (vx, vy, vz)
a rotation matrix around x-axis Rx(theta)
| Header 1 | Header 2 | Header 3 |
| 1 | 0 | 0 |
| 0 | cos(theta) | -sin(theta) |
| 0 | sin(theta) | cos(theta) |
Is there a way of finding at which angle theta the z component is the highest?
Regards
JXB
Header 1 Header 2 Header 3 1 0 0 0 cos(theta) -sin(theta) 0 sin(theta) cos(theta) Is there a way of finding at which angle theta the z component is the highest?
Here's a starter for 10 ...
Stuart
The z component of the rotated vector will be vy*sin(theta) + vz*cos(theta)
Differentiate wrt theta and set to zero to get the maximum theta as thetamax = atan(vy/vz)
(Check that it is a maximum not a minimum!).
Alan
Stuart
Thanks Stuart for the input. A lot more that I anticipated! I can see what I need I think
No worries, JXB. ![]()
Stuart
