Finite Element Analysis - where to in Prime/Mathcad?
KarlBogha
Hello All,
I just started chapter 2 on my finite element analysis textbook.
I would like to start with using Prime/Mathcad for FEM computations.
Where do I go to begin this process?
Is there a tutorial you came across for FEM using prime?
Any relevant answers in addition to the questions welcome.
dd//
N/A.
6 REPLIES 6
Some elements of FEM (sorry for tautology ) with Prime using you can find here Study 18. Differential Equations in Thermal Engineering
See please figs 18.10 & 18.11.
I hope it help you a little.
KarlBogha
(To:ValeryOchkov)
Hello Valery,
That was helpfull. I could relate to some of the examples I did in my textbook in chapter 2.
I did not know we had a entry field for FEM something like solver.
I will have to get to a tutorial on this in Prime/Mathcad, if there is one so far had not found.
N/A.
Hi Karl,
The following topics will be useful for you:
For Mathcad Prime you can order worksheet library - "Mechanical Engineering" which includes "Finite Element Beginnings" section, here: PTC Webstore
JK_9625275
(To:KarlBogha)
The attached file is for a 2D beam problem solved using FEA.
It is completely worked out and shows all of the functions and needed steps.
JK_9625275
(To:KarlBogha)
I've been using Mathcad since it was first introduced in 1983 (before windows).
Mathcad is my go-to tool for all engineering calculations.
JK_9625275
(To:KarlBogha)
You said, "Is there a tutorial you came across for FEM using prime?"
No, I learned FEM method in the 80s when the company I worked for was contracted to fix several bugs in NASTRAN.
I was tasked with the updates.
I rewrote the element stiffness model for 2D and 3D beams.  As far as I know, my beam elements are still being used in the NASTRAN program.
Jack
