Fonction fileopen
MartinBRUNET-di
Fonction fileopen
Bonjour,
Je cherche � ouvrir � partir d'un bouton de type pushbutton un fichier matchcad de r�f�rence.
Pour cela j'ai essay� diff�rentes functions en vain.
Quelqu'un connait-il la fonction � mettre dans le script pour ouvrir un fichier?
Merci,
I am trying to open a file with a pushbutton. For that I used the script editor of that button. Unfortunately I did not find the good function.
Does someone know it?
Martin
I happen to have done that in the past.
Richard
Thanks you very much!
Regard,
Martin
Following the last question I would like to do the same thing but with a template file (xmct).
Unfortunately, if I use the solution you gave me, Mathcad opens the template file as a classic file.
Do you know hou could I do?
Martin
>classic file.
Templates always open just the same as any other worksheet.
Richard
