I have defined function with "for loop" inside for table content processing. It looks simple, but unfortunately it doesn't work. Instead of calculation results , the message "This value mus be a scalar a matrix" is being displayed.
I was using this function with Mathacad 15 and it was working fine, but I can't reproduce it within Mathcad Prime 8.
Where did I go wrong?
Bogdan
ttokoro already pointed you to the error.
You had an implicit multiplication between "(rows)" and "N.t.".
It should read "rows(N.t.)" instead!
Now you should get the expected result:
You can achieve the very same result without any utility function in one go using a boolean comparison and vectorisation
Another option is using a simpler utility function, written to be used with just one scalar and called vectorized.
Here are two example for that kind of utility function
rows(Nt)
Maybe try
Thank you for all advices, issue is solved.
Bogdan
