Fourier Transform-symbollic
deanbs-disabled
How to find Fourier Transform symbollicaly
for the function attached
thank you
rb
rb,
in general you'd better supply a Mathcad file where you've prepared the work as much as possible...
Anyway, is this what you're looking for?
I have found that symbolic operations need a lot of handholding, and the user's intelligence in manipulating/interpreting results. I have used the symbolic F.T. infrequently, partly because of the work needed to manually review and sort out spurious results.
See attached.
Lou
Why bother with the symbolics? You can test the
answers and get no agreement.
