French Keyboard Not manage properly !!!
Doudoune31
The French keyboard is not properly manage even in the French version of MathCad Prime 2.
Example, when I press the Hat (^) I should include an exponent but this is not the case.
All shortcups given in the help bubbles are WRONG or FALSE !
An other unusefull or unseable function !
(To:Doudoune31)
Similar in the German and I guess most other localized versions. Its a shame and we will see if its fixed in Prime3 (rather Prime 0.3 IMHO).
BTW, I don't think it makes much sense to put this statement in a blog post. Would be more appropriate to open a discussion/question.
How do you do that ?
(To:Doudoune31)
If you go to the branch you want to post (in your example  PTC Community > Mathcad > Calculus & Des ) you see on the right side amongst others under "Actions" the option to "Start a discussion".
http://communities.ptc.com/community/mathcad/post!input.jspa?containerType=14&container=2048
Try to contact with PTC tech support by using "Mathcad Support Center": http://www.ptc.com/support/mathcad_supportCenter.htm
