Hello Everyone,
and the above is similar to :
Is there a way to solve X0, X1, X2, X3 with a Program Function ?
Thanks in advance for your time and help.
Best Regards.
If I understand correctly, you want this result.
Greetings
Many thanks for your time and help, F.M.
. Could you attach .xmcd file for mathcad 14 ?
Regards.
Loi.
Many thanks for "the formula" of your program function, because :
Regards.
I would like to point out that the result has only symbolic meaning. To get a numerical result, you should do so:
Hello Everyone again,
and
Solve, X[0, X[1, X[2, X[3 symbolically ?
Thanks in advance.
Regards.
