Gaussian Elimination for a system of equations
Gilgamesh
Hello guys,
I'm new into Mathcad Prime and this community, so please bear with me.
I'm trying to make a template to solve systems of linear equations with the Gaussion Elimination method.
I would like to know, if anyone in this community has a template to solve any kind equation systems with Gaussian Elimination?
I have attached a file with a system of equations, that I would like to solve with such template.
Thank you!
PS: I use Mathcad Prime 3.1
12 REPLIES 12
(To:Gilgamesh)
No, you didn't. All we see is the picture. At the time being you are not allowed to attach Mathcad or Prime files directly - you have to put them in an archive first (zip, rar, ..)
So you are not interested in the simple solution of such system, right? There would be a lot of different ways you could achieve that in Mathcad. You want Mathcad to show you step by step how to do it manually using the Gauß algorithm, right?
Mathcad is not made for showing you the calculation steps but rather will give you the final result only. I gues with some programming it would be possible to achieve what you are looking for, but then - why? There are websites which will do exctly that, no need to reinvent the wheel, I guess. E.g. a German one is http://www.arndt-bruenner.de/mathe/scripts/gleichungssysteme.htm A possible outout of that site is in the attached file.
Gilgamesh
(To:Werner_E)
Thank you for your answer. Let me clarify my request with the following simple example: In the attached picture, I have set up a template to solve a system of linear equations with Cramers Rule. I can fill the matrice, and the results pops up, but the important thing is, that it shows the steps necessary to calculate the the solution.
I had something similar in mind for solving systems of linear equations with Gaussion Elimination, but I couldn't establish a general rule to solve them that way.
(To:Gilgamesh)
I already guessed that you would like a sheet which shows you the single steps of the Guaß solution as on the web page I linked you to.
It would require some programming to generate the various matrices until you arrive at the upper triangular matrix.
You would have to decide which variant of Gauß you'd like to use (with or without pivoting, Gauß-Jordan, ..) and also find a way to deal with systems which don't have a unique solution (either no solution at all or an infinite number of solutions depending on one ore more parameters).
So this would be quite some work and I doubt that anybody here would be willing to this for you. But if you want to give it a try and experience problems you sure will find a helpful hand here.
Your Cramer sheet (better: the pic you posted) does in no way show the calculation steps necessary. We son't see the determinant filled with numbers, we dont see the values of the determiants. All we see is the method how to calculate the results using determinants. Furthermore your sheet will work only with 3 equations in 3 variables and will throw an error if the solution is not uniqe (determinant of coefficients = 0) without distinguishing between the two different cases whoch can lead to that error.
Gauß is not a method that rigid as Cramer - the single steps would depend on the concrete values used. Especially when you implement pivoting. Thats why programming will be required.
BTW - whats the reason for your wish to have that kind of sheet. What will the purpose of it be?
Gilgamesh
(To:Werner_E)
Yeah, it definitely has some limits.
My reason for seeking such template, is for my math exam.
I've seen that some people have tried to make such template with programming (they made a for-loop, i think), but I have no experience with programming, so I will just avoid that solution.
But it seems like there's no simple way to create such document, so I'll just forget it.
Thank you for your replies and time 🙂
(To:Gilgamesh)
Why don't you just use one of the websites which as it seems provide exactly what you need?
I am sure the German one I linked to is not the only one and you will find ones in other languages, too.
As for Mathcadm Gauß and programming - you might find those links interesting. It sure would be necessary to change the programs to give you a full list of the matrices in the various states, but it may be a starting point:
http://www.math-tech.at/beispiel.asp?id=101
https://www.coursehero.com/file/10751007/Mathcad-Gauss-elimination-generates-LU-factors/
Both deal with older version of Mathcad, but that should not be that big a problem.
Gilgamesh
(To:Werner_E)
Oh, I've found several online calculator to do the job, but internet is prohibited during exams 🙂
I will into the links you've providede, thank you 🙂
(To:Gilgamesh)
And computers with Mathcad are allowed!? Surprising!
Good luck!
P.S.: You may also search this forum for "Gauss elimination". You should get a lot of hits - maybe some are useful for you.
(To:Gilgamesh)
In case you don't know how to solve linear (and also non-linear) systems in Prime, here are four ways to solve your system:
Prime file (format 3.0, you should be able to open in with P31) is attached.
¡Hola! He leído tu inconveniente, creo que puedo ayudarte con tu duda. He programado en MatchCad el algoritmo del método de solución de Gauss y el de Gauss-Jordan. Si bien es cierto no podrás ver el paso a paso, podrás entender qué operaciones se realizan en los bucles y a qué partes de la matriz afecta. Si tienes dudas al respecto, puedes escribirme.
So you are hoping and praying  that no diagonal element in the coefficient  matrix is zero? 😉
Tienes toda la razón. Gracias por hacerme ver el error. Aquí está el código modificado para evitar ese error. Si encuentran otro tipo de inconsistencia, hágalo saber para poder mejorar.
You should attach your worksheet rather than just a pdf.
Your modification seems not to solve the problem as the algorithm itself can create a zero in the vital diagonal element.
Lookup the algorithm in the literature with special interest in 'pivoting'!
Pivoting is also used to look for the largest (absolute value) element for the diagonal to make for better stability of the algorithm.
Try your algorithm with this example:
or
If you have further questions, it may be beneficial to open a new thread for them, attach your worksheet and state, which version of Prime you are using.
It may well attract more potential respondents if you make the effort to translate your text into English yourself rather than leaving this task to the reader.
