Gestion des sections
MartinBRUNET-di
Bonjour,
Je souhaite d�sormais g�rer l'ouverture et la fermeture de mes sections de mani�re automatique.
Par exemple, si A > B section ouverte
sinon section ferm�e.
I am now looking for a solution in order to control the opening / closing of a section automatically.
Example :
If A > B the section is opened
else the section is closed.
Merci
Cordialement / Regards,
Martin BRUNET
There is no way to do that automatically. At least, no simple way. It's probably possible by using a scripted component to change the XML in the file, but it would be a lot of work to figure out.
Richard
Thank you for the answer.
Can you give me few details about the XML option that could be work?
It would be very usefull if I could manage the section automatically.
I can also use a pushbutton if necessary.
regards.
Martin
