Given_Find( X,Y,Z )
lvl107
20-Turquoise
Given_Find( X,Y,Z )
Thanks in advance for your time and help.
Best Regards.
(To:lvl107)
That way you changed your vector X.
I had something like this in mind
11 REPLIES 11
(To:lvl107)
You need two more equations. Otherwise you may chose two variables freely and can calculate the third.
The questions doesn't seem to make much sense.
lvl107
20-Turquoise
(To:Werner_E)
Many, many thanks, Werner.
Best Regards.
May be so:
lvl107
20-Turquoise
(To:lvl107)
Hello, again.
Best Regards.
(To:lvl107)
You should remember from former questions of yours that Mathcad's Find won't work with indexed variables!
Can you further explain what you are trying to do at the end? What are all this calculations for?
lvl107
20-Turquoise
(To:Werner_E)
Best Regards.
(To:lvl107)
It works if you try reciproke values.
Whats that all about?
lvl107
20-Turquoise
(To:Werner_E)
Many thanks, Werner.
Best Regards.
(To:lvl107)
lvl107
20-Turquoise
(To:lvl107)
Hello, again.
And related question :
Best Regards.
(To:lvl107)
Whats considered as "simple" and maximal simplified might differ depending on the purpose.
Whats the purpose and the end goal in this case? There might be a way to achieve the end goal without splitting those expressions in sums of fractions.
E.g. it would be easy to write a recursive function to produce all your expressions q, Q, etc.
