In mathcad 15, there is a bug where MathCAD doesn't draw all the lines when they share a point eventhough they are seperated by NaN.
I have attached an example of what happens. I also tried the same thing in prime 1 and it seems to be fixed.
Is there any work around for this in mathcad 15, Prime doesn't have the futures I want.
Borhan,
Double click on the graph and on the format menu,cChange the "type" from "lines" to "draw"
It is a bug, but this works.
Borhan,
Thank you.
