In the attached Prime 3.0 worksheet I am attempting to graph a function of functions. This is something that I did readily in Mathcad 15. Is this possible in Prime 3.0? Is there a change I need to make to this function to make it graphable?
This sheet won't work in Mathcad, either!
1) Axis ticks are not allowed to have any units
2) If you want x to be of unit ft you have to provide an appropriate range variable
3) M_ALIVE and M_DEAD have wrong units (kip instead of kip*ft)
