Greek Letter in MATHCAD 15 Table??
regcurry
Ctl g does not work.  It teverts to regular text.  Is this possible in any table or matrix.  The text is in quotes in the table.
Reg
(To:regcurry)
I was talking about the "Alt Gr" key ('Alternate Gray') to the right of the space key which is used to get the superscripted "3" which is a special character in the character set.
This works on my German keyboard and according to the information from the net also for US keyboards
"Alt Gr" can be replaced by Ctrl+Alt. So pressing the threes keys "Ctrl" Alt"  and "3" at the same time and then releasing them should also create the character ³.
The key may read just "Alt" instead of "Alt Gr" and depending on the keyboard you are using it could be that you are not able to create the superscript 3 via the keyboard at all.
In case you cannot create that character from your keyboard, an easy alternative is to use the text "^3" instead even though it may not look that nice.
But there are other ways to create the superscript 3:
You may copy the ³ character from character map
or you may create it using Alt+0179, which means keeping the Alt key (to the left of the space key) pressed while you type 0179 on the numeric keypad and then release the Alt key.
14 REPLIES 14
(To:regcurry)
I understand your question to mean that you want to use Greek letters in a string variable.
Unfortunately, the editing options in a string are indeed very limited. For example, you can't select individual characters to copy or delete them, and, as you noticed, the shortcut Ctrl+G doesn't work either.
You can still use Greek letters, however, by copying and pasting them into the string. You have at least three options:
1) Start the Windows program "Character Map" and copy the characters from there.
2) Create a math region (a variable name) in Mathcad using greek characters and copy from there
3) Create a text region in Mathcad using greek characters and copy from there
Thanks, butt I cannot see how to use it in a table.
Reg
(To:regcurry)
You cannot copy a math regions which contains math operators like division or exponentiation. just copy the rho to a string and type the rest
When I paste it into a cell I get “.” and not “rho” in the cell.  I must be missing something.🥴
Reg
(To:regcurry)
I first created the string "s" you see in the picture and then copied the whole string (including the quotes) to the table-
One more thing.  I don’t create s:=.  I just created text and pasted rho from the character map.  🤷‍♂️
Reg
I thought that is what I did. Are you using Mathcad 15 or Prime?
Reg
(To:regcurry)
I am using MC15
Step by step:
1) type   r Ctrl+g   to create the rho (actually a variable name)
2) Press Shift LeftArrow to highlight the letter rho and press Ctrl+C to copy it to the clipboard
3) At a different place type s:" and press Ctrl+V to insert the letter rho
4) Continue type space (gm/cm³) to finish the string
the ³ is not typed using the exponentiation operator but is typed from the keyboard (AltGr+3)
5) Now using mouse or keyboard highlight the whole string including the quote and copy & paste is to the table cell
Sorry to be so dumb.  I got the ρ in.  Now to get the exponent is it Alt+>+3.  I’m not familiar with keystroke Gr.  Is it >?
Reg
I don’t have a Gr key.
Reg
(To:regcurry)
👍 Thanks much.  That worked.😁
Reg
(To:regcurry)
Glad you got what you were looking for.
In case you need higher exponents than 3 you have to get them from char map anyway
Reg Curry on iPad
Reg
