HARI KRISHNAN
ptc-4561969
HARI KRISHNAN
Gud noon
Am hari working in a automotive industry, am using mathcad 15, i need an solution for the below
Example:
the result of sum is C= 60 mm
i give the condition like
C should be greater than 80, if the result came below 80,
an notification should appear on window like "OK" or "NOT OK" or Highlighting that value
Can anybody assist to me
Hari
9944959750
Have a look at them attached.
Mike
8 REPLIES 8
Mike
Or so - see attach (without scrips)!
Nothing attached Valery.
Mike
Mike
You're so impatient Mike!
My apologies.
Mike
Very nice indeed.
Mike
As requested, the worksheet will now work with a tolerance.
Mike
Cleaned worksheet attached.
Mike
