I want to solve the spectral moment from DNVGL RP F105 standard (see fig.2) but in my Mathcad worksheet (see fig.1)the calculation does not converge to a solution. Could somebody please review my work? The file is attached below.
Thank you for your help!
Basyarulfig1. my mathcad worksheet
fig.2 equation from standard
Another Correction, sorry I missed this.
The transfer function is also defined in terms of the variable "wl". This changes the answers.
Cheers
Terry
May be this help you:
You need to integrate a function with respect to a variable used in the definition of the function.
Enclosed is the solution to your problem.
Cheers
Terry
Cheers
Terry
Thank you for getting back to me, Terry!
