Help With Programming
ppal
18-Opal
(To:ppal)
Remark:
You could also do without using a user-written utility function, but I sure would prefer using the function
or even without an extra range variable, using "submatrix"
6 REPLIES 6
VladimirN
(To:ppal)
Please don't forget to specify which version of the program your Mathcad Prime worksheet is for.
Prime 8
ttokoro
(To:ppal)
LucMeekes
(To:ppal)
More precisely (without retyping numbers causing accuracy loss) you may get:
Then why not simply (without detour):
(To:ppal)
Why not use a utility function which can deal with vectors of arbitrary length?
And in case you are interested in the exact values, you can use symbolic evaluation
(To:ppal)
Remark:
