Help creative list steel ID same picture.
dhs
8-Gravel
8-Gravel
Hi Friends.
I have a question to day. I am learning Mathcad 3.0, when I look up video PTC Mathcad Prime 3.0 - Features and Functions - YouTube  at 1:40 min.
What is video use tool ceating ID same video at 1:40 min. Can you tutorial creating same shap I.
thanks.
(To:dhs)
Looks like an embedded Excel-table from which the values are taken.
Below the table you see a plus sign and a horizontal line. This is a collapsed area which probably contains the regions which select the appropriate values from the table depending on the value of the globally assigned variable ID.
The video you refer to sure is not a tutorial you may learn from but rather a commercial.
(To:dhs)
dhs
8-Gravel
8-Gravel
(To:Werner_E)
Thank you.
