Hello, Everyone.
solve, W, X, Y, Z ?
Thanks in advance for your time and help.
You have one (1) equation and four (4) unknowns.
I have one solution for you:
W=1, X=3, Y=5, Z=7
Proof:
W=1, X=3, Y=5, Z=7
Proof:
Thanks for your time and help, Luc.
1. And I guess the above solution is a unique solution (?). And I don't know how to prove that.
2. Is there a way to convert any fraction to the other form that is similar as the above ? ( I called that is Lambert form ).I do the conversion by hand and I don't know that is right or not ?
I don't know if the solution is unique. So far I let my brute force search method run for n=39 and found no other.
