Help with DE
RosenMITREV
3-Newcomer
Help with DE
Dear colleagues!
I have a problem with simple DE. Please see the attached documents. Maybe my question is answered many times, but i didn't find any help.
Thanks in advance
Rosen
Няма проблем, Росен. Имате добро себе си седмица.
Stuart
6 REPLIES 6
See attached - you can't pass the function name as a parameter within the solve block.
Stuart
Dear Stuart, thank you very much! Your solution completly solves my problem!
Have a nice week
Rosen
Stuart
Dear Stuart, would you like to help me one more time? Please, see the attached file
Thanks in advance
Thanks in advance
Hi Rosen,
See attached. There is a severe limitation on the solution, though. It works by augmenting the solution vectors into an array and then plotting the array. The problem is that it is (effectively) one trace, which therefore has one colour making the individual plots pretty indistinguishable (they'd be hard to see anyway!).
I think I've got a worksheet somewhere that uses a 3D plot to give an improved display - I'll see if I can find it and adapt it to your data.
Stuart
Ok, thanks! What about Fc(t,x,delta)? How to plot this function as a function of delta?
Years ago Tom Gutman sent me the attached file, may be you speak about it?
Rosen
