Appreciate if you help to fix the error in the attached sheet
Thanks in advanced
On the right you have images taken from a Mathcad 15 or earlier worksheet.
Why don't you use the XMCD,MCDX Converter found on the Prime Ribbon at Input/Output to convert the original file to Prime?
Cheers
Terry
Enclosed sheet.
I have put in the indices used in the original worksheet.
I have corrected a formula.
Still a problem with two equations but I will work with them some more.
Really I'm so grateful sir, I'm waiting for your nice work
Thank you so much really you solved the puzzle and broke the knot 😍
фаил не открывается 😠
