Hi all, Have anybody got idea about how to plot Fourier summation problems by Mathcad? i have formula i want to plot i found it difficult. Any help please ..Regards, farha
fnashad
See attached file
You need to read the help files a bit more.
Some short notes:
  •        you don't need ; bot j and i are built-in constants for imaginary numbers  (type 1j or 1i without a multiplier between them
  •      when something turns red,  , Mathcad doesn't understand.  (In this case you haven't defined the value for i, but you're using it as a subscript.  Any future reference will fail.
Some short notes:
Hi FredKohlhepp,
Thank you for your reply , i corrected the red ones ,i have got some values for Z(f) but still no plot graph
please post your corrected sheet.
Attached is an example of how to use Mathcad with units, the equations won't bear close scrutiny, but the example is worth looking at.
