Horizontal axis in terms of pi
fizzy
Hello all..
When creating a 2D plot, is there a way to have the plot show the horizontal axis ticks in terms of pi rather than real numbers?
Here's a simple plot of f(x) = 2sin(4x)
The horizontal axis shows -10, -5, 0, 5, 10
I would like to add more ticks to this, but more importantly I would like them to be in tems of pi.
I looked through some of the previous posts, and MC 15 help, but I haven't found anything pertinent.
Any ideas?
(To:fizzy)
Unfortunately - no. Thats another rather old, long standing but unheard user request.
9 REPLIES 9
tietjee
(To:fizzy)
Select end point of the x-axis as multipes of pi
fizzy
(To:tietjee)
Thanks for the file and the quick response, but the x-axis on your plot consists of real numbers, not in terms of pi.
(To:fizzy)
fizzy
(To:Werner_E)
Werner....
Seriously?!
(To:fizzy)
Thomas Hartman wrote:
Werner....
Seriously?!
As long as you want integer or inter fraction multiples of pi displayed - yes. If you are happy with decimals representing multiples of pi you may try what David suggested.
The best I can come up with is this (and the x-axis labelling is abit confusiong because of the missing pi)
fizzy
(To:Werner_E)
Thank you......I could just copy the plot and then past in the values, but I was just flabbergasted this couldn't be done in mathcad.
Thanks Werner
(To:fizzy)
Its indeed often surprising how apparently simply features are missing in otherwise high end software products.
The result is just like all plots with units, and here pi is a unit. For plots with x as a distance in ft, for example, we don't see "ft" at each tick mark. Instead, we see numbers in the selected unit. We select the unit by dividing x by the unit, just as you have done with pi.
To show the units, create a label for the x axis, such as "angle in pi"
Yes I know and using pi as a unit here is just a weak workaround to get closer to what Thomas had originally requested (and a lot of simple plot programs do offer).
I also tried it in Prime - here you can put the pi in the unit placeholder of the axis label, but you have to define pi:=pi before, labelling the lefthand pi as unit.
Wish Mathcad would be able to label in multiple/fractions of pi without having to resort to this trick.
