How do I get the maximum of two values ​​from different units?
Yabo
3-Newcomer
Hi everybody
Im trying to determinate the maximun of  two values with different units, but Mathcad does not allow it.
t:=2m
h:=5kg
Max(t,h)= ?
Help me pls 🙂
Here is a worksheet.
7 REPLIES 7
Hi
Max(t/m,h/kg)
Cheers
Terry
LucMeekes
(To:Yabo)
And for good reasons! Essentially you're comparing apples to oranges, or pears, or berries... In general it's nonsensical, certainly from a physical standpoint.
Bear in mind that if you express t in mm, and h in kg, then 't' will provide the larger value.
Yabo
3-Newcomer
(To:LucMeekes)
I need the maximun of these two values.
These formulas represent the maximun reinforcement bar.
LucMeekes
(To:Yabo)
That is only possible if
 f ' c
is unitless.
Otherwise, as explained, it's nonsense.
Where is the worksheet...?
These are empirical equations the result of both is mm^2.  Using empirical equations you must be careful to divide the inputs f'c, fy, b, d by the right units as used by the creator of the empirical equations..
Cheers
Terry
Thanks bro! Have nice day.
