I am trying to do a symbolic solution for the distance in feet for a given free space loss in dB and frequency in MHz. The formula originally came from a canned Excel spreadsheet.
Now want to solve for the distance in feet for a given frequency and free space loss.
Doing a symbolic solve,
Mathcad 15 M010 says cannot find a solution.
Mathcad 11 finds a solution in terms of the frequency in MHz and "lhs". What does "lhs" mean????
I need to be able to put this back into a spreadsheet, so can't use units here.
Bill
This works if you reformulate it just a bit!
"lhs" translates to left hand side
Nicely done Fred.
Mike
Well, I get two e-mails. But the answers from Fred and somebody else do not appear in the discussion. I will wait.
Bill
I opened your file (*.mcd) using version 14, modified it to solve your problem, and saved it (*.xmcd)
Version 15 (which you say you have) will open that file, and it should display the same answer I got using 14.
What are you waiting for?
Fred & Mona,
When I log into the community with my work login, Bill Dumke, all I see is my first post. When I log out I see all of the thread, including your posts, Fred. So I just tried logging in with my home user name and password, William E. Dumke, and now it looks like it works.
Fred, thank you for the solution. I didn't know I could use a function in a solve block like that.
Mona, please fix this, so I can give Fred the credit for the solution. I can't do that from this log in.
Bill
