How it into the matrix ??
Athur
Hi. I want Formula into the matrix. thanks
15 REPLIES 15
AlanStevens
(To:Athur)
N(x) only has one column, so it's a vector. There is no need for a column selector. However, if you must have a column selector here then, because Mathcad starts counting at zero, you must use <0> not <1>.
Alan
Thanks.
But I do not.
You can edit file help me?
I is attachment file.
AlanStevens
(To:Athur)
dongchi 420 wrote:
Thanks.
But I do not.
Here you are trying to use the column selector (Ctrl_Shift_C) to select rows. You need to use the row selector (Ctrl_Shift_R) for this. However, Harvey's method is much better when selecting a single value from a vector.
Alan
You created N(x) using a range variable x. Therefore, N(x) is a range variable too. You can not refer to a single element of a range variable.
Create x as a vector. Then create N(y) as a function of a single value. N(y):=R*b*y. Then you can pick any element of the vector x to use for the argument. e.g.
N(x[0) for first element of x. [ is the subscript operator
Thank Harvey Hensley.
I have done. verry good.
THank agian.
Athur
(To:Athur)
hi all.
I is prolem. Please see picture. THanks
File is attachment
The index of variables (vectors) must be integer!
Describe please with words not with Mathcad-operators that you want to do.
Something like the following:
Athur
(To:Athur)
thank you .
A very good way of doing
I'm glad you liked it. Now, please tell me what software you used to annotate your screen shots with red rectangles, arrows, and text?
Looks like he PDF'd his file and added the annotation to the PDF via a PDF program like Adobe, Foxit, etc.
Yes correct. I use Acrobat for similar marking of documents.
Mike
hi.
I use program jing. You can download http://www.techsmith.com/jing.html
Thanks, dongchi. I'll give Jing a try. And thanks to EL CID and Mike for their suggestions also.
VladimirN
(To:Athur)
Thanks.
