How to Obtain and Plot Variables from a Loop Calculation
ptc-5031264
I have programmed a loop calculation to obtain three variables which I want to obtain in a Table format and then plot two variables on a graph. The varibles I need in the Table format is a, Lrp and Kr. Once I obtain these values, I want to plot Kr on the y axis and Lrp on the x axis on the graph shown in the mathcad sheet. Basically I should have a locus of (Lrp,Kr) points on the graph. I have attached the mathcad sheet. Your help is deeply appreciated. Thank you.
Ranjan
(To:ptc-5031264)
The file you attached the second time looks like the one you attached first!?
Anyway, are you looking for soemthing like the attached?
Sorry, I attached the wrong file.
(To:ptc-5031264)
In the meantime - is something like http://communities.ptc.com/message/201034#201034 of help?
(To:ptc-5031264)
