How to create a vector with the minimum values of two other vectors?
DrilonShabani
If I have a vector A and B both with 10 elements. How can i create a vector  C that has the minimum values of A or B on each corresponding position.
Thanks in advance !
Use vectorization.
But as min can't be vectorized, we have to write our own min function, calling the built in min.
5 REPLIES 5
Use vectorization.
Short, simple and clear . Thank you very much
LucMeekes
(To:Werner_E)
Is there any good reason why min (and max, and mean and stdev) can't be vectorized?
I think all the above answers for the xxx1, 2 and 3 functions are OK, so they could (should!) have been produced by vectorizing the original function immediately.
(To:LucMeekes)
I, too, can't think of any good reason why min and max should not allow vectorization.
LucMeekes
(To:Werner_E)
I see you've given that a thorough thought. 🙂
