Is there a way to display only the output of an equation? For example, if I define:
Is there a way to only display the 93.6% later in the document? Without having the variable, Mcw_C6_V, displayed? I would like to summarize my calculations at the bottom of the document but allow them to change automatically if I change calculations earlier on in the document.
It is possible, and fairly easy. Prime 4 file attached.
But why would you want to present just numbers?
I don't believe sp.
it is possible with the use of controls. I've added a MC15 sheet that shows how to do it.
Cheers
Very clever, chicanery worthy of Val Ochov!
Thank you very much Fred. Attention from your side counts twice.😊
It was a challenge I couldn't resist.
I first tried it with a text block with white backround. But it wouldn't stay on top of the equation. I also experienced that text blocks and equations tend to align differently.
But another equation does. Other advantages: Aligns good with the equation and the grid still shines through.
Still wonder why the OP wants to just present numbers...
Suspect he's looking to build a table. . .
Thank you very much! It looks like this is as close as I will be able to get.
For all of you that are wondering...I am calculating many margins on components throughout my document and at the bottom, I would like to include all of these margins in a tabular form, listing each component name and the margins for each parameter. Basically, the variable is irrelevant at this point and would just clutter the table.
You could build a matrix that could be made to look like a table.
