Dear All,
How to Obtain tha value of X for a particular S value between S1 and S2. Y is assumed to be known.
i.e, what will be the X-Y plot for a S value between S1 & S2.
Work please with picture. I cannot save as Prime 2:
You will have to interpolate between them.
One solution
The Y values on your graph are not the same as the Y values in your table. If the Y values in the table are plotted against X the only difference between the plots is the intercept of the lines. In your graph it looks like the only difference is the slope of the lines (although small differences in the intercept may just not be visible).
Please provide the worksheet.
Looks like simple 2D interpolation.
You'll have to privide a worksheet.
Thank You all for the response... The solution provided by Valery Ochkov is what exactly i want. Let me try with that and provide the worksheet soon.
saranya tl wrote:
Thank You all for the response... The solution provided by Valery Ochkovis what exactly i want. Let me try with that and provide the worksheet soon.
I am glad to help you:
http://twt.mpei.ac.ru/ochkov/TTMI/1/1-1.xmcdz Mathcad 15
http://twt.mpei.ac.ru/ochkov/TTMI/1/1-2.mcdx Prime 3
All from
http://twt.mpei.ac.ru/ochkov/TTMI/1/1e.pdf
(The Chapter 1 from my new book "Thermal Engineering Studies with Excel, Mathcad and Internet" - http://twt.mpei.ac.ru/ochkov/TTMI/Preamble.pdf)
Those Document were really useful. I am getting an error of Unit Compatability.
Kindly find the worksheet attached herewith.
See the attach
I am unable to open that file. I am using mathcad prime.2.0.
It is very popular problem in India
See please http://twt.mpei.ac.ru/ochkov/TTMI/1/1e.pdf
It is working.... Thank You soooo much...
You welcome!
More difficult interpolation (with spline and linterp) I show here with animation
