Thank's in advance
Attach please the Mathcad sheet!
ok sorry, done..
What is the value of K?
This is needed for the solution.
Cheers
Terry
Not sure if the following is near to what you are looking for:
P6 worksheet attached
Hey,
The hell you mean “what does T mean in algebra” it's a variable the same as X and Y are. If I said “solve the following equation x + 2 = 8.” Your answer would be 6 right. So if I said t + 4 = 6 It would then be 2. T is an unknown variable the same as X and Y are.
