Mathcad Prime gives me 11.833 as answers but need to get and show the equivalent fraction 71/6.
How can we convert from decimal to fraction?
It appears you cannot.
In version 15 you could format your result as a fraction. If you do that and convert to Prime (3.0) the result is a decimal. Prime (again, 3.0) does not have "fraction" as a choice in Math Format.
New rational number ![]()
Unfortunately I didn't bother to install Prime 3.1 (just 3.0) and so I can't read your file and don't see what you are doing.
As Fred already stated is the inability to format a result as fraction one of the many missing features of Prime (compared to Mathcad).
Maybe you could use symbolic evaluation?
WE
Many thanks Werner, but in this case really appears can´t.
Get rid of the numeric evaluations
Awesome!
Many thanks Richard, It really works.
