How to label a family of curves?
Cornel
These curves are displayed best by using logarithmic axes.
The plot result should look like below: I am interested how to put that Rg/Ri on each graph.
ttokoro
(To:Cornel)
Using Luc's stroke data sets. Linear plot of stroke data is overrayed.
9 REPLIES 9
(To:Cornel)
Prime does not  support any labels in its native 2D plots. You would have to create text regions and place them manually. Given the coarse grid used by Prime even if you chose the "fine" grid this sure can be demanding.
Not sure about the Chart component which supports labels because I can't use it. I guess here you could use different colors and line styles and provide the names in the legend. Of course this means that you can't use the waterfall plot to plot all curves  in one go but rather have to plot each of the curves individually to be able to give it a unique color/line style.
Cornel
(To:Werner_E)
How to define a function like this? As I do not see slash button when defining a function. Right now its a text. But if you press slash button on keyboard in a math region you will get the division line.
(To:Cornel)
maybe that way 😉
Start with a string by typing " and then delete the quotes. subscripts must be done after deleting the quotes.
You can create a lot of funny variable names that way, but some characters can't still be used. E.g. you can't create a variable name with a space in it or a variable name which starts with a number.
Cornel
(To:Werner_E)
But on which buttons did you pressed to be able to put this slash in the math region?
(To:Cornel)
See the explanation which I added in my answer above.
Cornel
(To:Werner_E)
Ok, understood now.
Catalina
Moderator
(To:Cornel)
Hi @Cornel,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
ttokoro
(To:Cornel)
ttokoro
(To:ttokoro)
Only 1 x-y plot to show all data.
