Hi guys,
I have a problem with an integral that I would like to link in the solve block using odesolve.
The Integral (sin A(s) ds) can't be written in the solve block or the solution can't be found. I tried to rewrite the integral in a sum or I tried to use the trapezoidel rule, but it doesn't work either.
A(s) isn't given, but dA(s)/ds will be solved during the solution.
I am looking forward to your helpfull answers 😉
Best regards
David
odesolve will not deal with integral equations.
Can you take the derivative of your equation to eliminate the integral?
I tried that last week and it doesn't work. Today I tried the same way an it works. Thank you very much.
As Fred says, odesolve doesn't solve integral equations. To comment beyond that, we would need to see a worksheet.
