How to reduce the blank area of a collapsible area
FW_10924800
3-Newcomer
I am new to Mathcad and have just learned the feature of collapsible areas.
Now, does anyone know how to reduce an unwanted area within a defined collapsible area? Understad the inserted area automatically increases to accommodate more content as writing. But when I remove some of the content, it won't shrink, leaving with a large unused space in the worksheet. I couldn't find anywhere one could manually drag that area to reduce its size.
Does anyone come across the same problem? I'm using PTC Mathcad Prime 9.0.0.
Frank
LucMeekes
(To:FW_10924800)
You should be able to delete empty space with the 'Del' and 'Backspace' keys of your keyboard.
That works as long as the cursor is on a 'line' that is completely empty.
LucMeekes
(To:FW_10924800)
Hi Luc,
Thanks for your answer. I tried and it worked perfectly.
This was my first question and I was amazed how quickly it got responded!
Enjoy your day!
Frank
(To:FW_10924800)
Apart from using the keyboard as explained by Luc (and which probably often is the fastest and most convenient way) you might as well try the ribbon menu (Document-Spacing-Remove Space) or the right mouse click context menu, where you also can choose "Remove Space".
https://support.ptc.com/help/mathcad/r9.0/en/#page/PTC_Mathcad_Help/to_add_or_remove_space_between_regions.html
https://support.ptc.com/help/mathcad/r9.0/en/#page/PTC_Mathcad_Help/about_context_menus.html
All methods have in common that the cursor must be placed between two regions (meaning in an empty space in-between) which sometimes can be demanding.
