How will I reverse data in a column matrix ???
aimtiaz
just consider the following matrix
I want it in reverse , this way -
How can i do this in math cad prime 3.1 ???
StuartBruff
23-Emerald V
(To:aimtiaz)
Use the function "reverse".
Stuart
6 REPLIES 6
StuartBruff
23-Emerald V
(To:aimtiaz)
Stuart
Or so
LucMeekes
(To:aimtiaz)
As indicated above , you use the function 'reverse' for that. Note that you can do:
(To:aimtiaz)
"reverse" is a built-in, ready-to-use function. So there is no need to reinvent the wheel 😉
The built-in "reverse will also deal with matrices, not just column vectors.
WE
aimtiaz
(To:aimtiaz)
many many thanks to every one  .........
One divertissement for you
Video Link : 6821
