Hydraulic Calculations in Pipe systems
DGCarter-disabl
Is there an easy way to set up a worksheet for hydraulic pipe calculations, specifically for Fire Sprinklers, NFPA 13D? I am new to MathCad, would rather use this than an Excel workbook.
Thanks in advance,
Geoff
You might see if there's any existing sheet here that you can use: http://www2.latech.edu/~dmg/
TTFN,
Eden
There are a couple of pipe flow worksheets located
there. I will check them out.
Don
