I need to extract one row of a matrix
bbond
I have a matrix of steel shapes and the corresponding section properties.
Currently for each section property I am using a vlookup function.  This requires I type in the shape of the beam inside each command every time.  There has to be a way to combine a vlookup and extract an entire row based on that lookup item.  I assume I could then put the extracted items into a single column matrix and have each passed into the variables.  This would allow me to only type the shape into a single lookup function.  I'm new to Mathcad so I'm probably overlooking the obvious, but I have searched for a solution and can't find one.  Anyone know of a way to do what I am trying to do?
13 REPLIES 13
MJG
18-Opal
18-Opal
(To:bbond)
Use "match" to obtain the row index for specified shape.  Then, use the matrix row function to extract it.
ValeryOchkov
(To:MJG)
MJG
18-Opal
18-Opal
(To:MJG)
Something like this:
Here's one way to then extract each of the individual variables with their units:
StuartBruff
23-Emerald V
(To:MJG)
This is the kind of situation where I'd almost certainly write a function to simplify things and make the worksheet easier to read (and, hopefully, debug / maintain).
In Prime, you'd replace the clumsy transpose/column-operator with just a row-operator (Mathcad 15 has no row operator and I don't have Prime available).
(In this instance, as there is only likely to be one AISC table, it would probably be OK to write the function such that it picks up AISC from the worksheet rather than passing it as a parameter.  The advantage of doing this is that it potentially makes the function less confusing to the reader.  In reality, I'd probably still define it as getLabel(AISC, label))
Stuart
tslewis
(To:MJG)
This is an elegant solution for applyign units.
One thing I found out, you can create local functions within functions, see below, pretty powerful
(To:tslewis)
Guess you posted in the wrong thread!?
Did you mean this one https://community.ptc.com/t5/PTC-Mathcad-Questions/Incongruence-in-matrix-units/td-p/482098
EDIT: Ah, no! I just realize that your post refers to a former post by MJG.
One problem:
tslewis
(To:Werner_E)
What is the issue? I don't want to apply units if the value is not intended to have a dimension. What if the value is NaN, a string or a complex number? How did you end up with units of m? Did you add those manual in the result ?
(To:tslewis)
No, I didn't add anything manualy.
You can give it a try yourself, but be sure to use the value 0 where i had done so.
Explanation for this behaviour can be found in the thread Io referred to.
tslewis
(To:Werner_E)
Aha - that is interesting, thank you for the tip!
bbond
(To:bbond)
Thank you all for the help.  I'll see what I can put together with this info.
(To:bbond)
1) You could define a variable for your shape like
shape:="W44X335"
and later use this variable in your vlookup commands.
A.g:=vlookup(shape,AISC,4)[1*in
2) As Mark already wrote you can use match to get the row number, like
rownr:=match("W44X335", AISC)[1[1
or to just search in the first column
rownr:=match("W44X335", AISC^<1>)[1
Then you could Primes row selector to assign a variable the full row of data.
You may even multiply this row (you would have to use the vectorization operator!) with a row vector consisting of the appropriate units for each column and assign the result to a row vector consisting of the Mathcad variable names like A.g, f, etc. and you have your single variables with just one command.
The attached may be helpful:
EDIT: Haven't seen Marks last reply before posting my own. I would prefer his "ApplyUnits" over my "multiply" 😉
I have a similar case. I have an extensive table with 5 columns (0 to 4) and more than 1000 rows!
I want to select the values for the first 4 variables (each variable in one of the first 4 columns) and find the row that contains the exact values I selected so to find the value of the 5th column (4) at that row.
Any ideas? Thanks!
tslewis
(To:bbond)
Use match function to find index of row and column of the steel function shape label, then use the mathcad function to extract a row based on the idea of row returned form match function
