You're using either 3.1 or 4.0, many of us cannot open this file. Do a "save as" and choose XPS--creates a file that's viewable.
Can you please check, its not working
Did you recalculate the sheet? What is not working?
OK, it works
Thanks you very much
Recalculate the page (F5) and it should work.
When you first open a Prime file, it shows in the state that it was last saved. Luc must have edited the file using Prime Express, so when we first open the file we see the same error that he must see (this is a premium feature...). Once you recalculate, the error goes away (because you have the full version of Prime) and the plot shows.
The attached is a similar approach, but saves a step.
Yes, thanks
