Attached, more details on a symbolic or numeric integration problem I'm working on.
I can pay for consulting, as a complete solution take some time...
...Larry
The attached might make some things clearer, though I'm not entirely sure what you are after in the last section of your workfile.
Alan
A complete numeric solution would need to consider both the offset d and the spin angle phi of the probe, and it would require a three-dimensional table lookup with a whole lot of data. It seems that the effect of phi may be small enough so it could be ignored, reducing the table to a manageable two dimensions. But I'm not confident in my math.
