Interchanging Row.
lvl107
20-Turquoise
Interchanging Row.
I really need help with following attachment file.
Regard,
Loi Le.
It usually best to start by defining some basic helper functions. Firstly because they are reusable for other tasks, and secondaly because the main program is then usually easier to write.
11 REPLIES 11
Regard,
Loi Le.
It's not clear from your worksheet exactly what your trying to do.
What does "Given Input Picture" mean?
Mike
AlanStevens
(To:lvl107)
Does this help?
Alan
Alan Stevens wrote:
Does this help?
Alan
Alan,
Have a look at the attached programmed method.
Mike
Alan,
Mike
Mike,
Strictly speaking you haven't interchanged the rows, just moved the positions of the numbers 1, 2, 3 and 4. This might be perfectly acceptable, of course, if all the other terms in the matrix are identical (as they are in the example provided). Certainly a programmed method would be more flexible than my "handraulic" method.
Alan
Alan Stevens wrote:
Alan,
Mike
Mike,
Alan
Alan,
Did you visit: http://communities.ptc.com/message/152308#152308
Nice Richard,
I that your method.
Mike
Regard,
Loi Le.
I have replied few days ago ... interchange row/col ... I think you were the visitor, but if you change thread for the same subject, that does not help !
jmG
lvl107
20-Turquoise
(To:jeanGiraud)
Thanks a lot.
Loi Le wrote:
Thanks a lot.
The kind of interchange looks a "rotation"
I thought that I was a bit late ringing in on this, until I saw that the thread apparently began in 2008 😉 Here are some routines that I threw together in 2006 to help with some work I was doing...I think that the advantage over the other method is that the matrix is transposed but once at the beginning of the routine and once at the end...oops 😉 I confused the "postings since date" with the "post date"...
~R~
