Is MathCAD 12.0 compatible with Windows 7
RobertOLeary
I am thinking of upgrading to Windows 7 but I am not sure if MathCAD 12 is compatible
Robert.
I have just seen on the eng-tips forum that Mathcad 12 can be installed sucessfully using a XP emulator on W7, but once installed didn't work.
Oh, and you probably don't REALLY want M12 if you can avoid it; that version was short-lived because it was extremely buggy.
Mike
Hi Guys
I know that you need to add an upgrade from our friends at ptc to use mathcad 12 on windows xp sp2. I guess you would need that as well, from memory you need to install MC12 then replace a file in the directory. then it will fire up before it will not open.
Cheers
James
