Is it a bug in prime 2.0 with Jacobian??????
  • January 24, 2013
  • 5 replies
  • 5621 views
I was about to start a simple problem...and bam! Prime2.0 has its own math AGAIN! I am using Version M010 BTW...
See attached of the Jacobian! I am sure the jacobian matrix is not 3X1.. and the Jocobian determinent is not 0
.Or did they change the syntax for Jacobian ?
Oh my god...why would I trust prime 2.0 for any math?
It has just way too much problem....come one..it is not the first time...
if you have seen my older posts..you know this is not the first problem that I ran into with prime 2.0........................
Best answer by Werner_E
I found it, but I don't know what its called in the english version. The argument xi in the function X when you call jacob is formatted as "variable" whereas the other as "none". So to Prime its not the same variable.
WE
23-Emerald V
January 24, 2013
Hmm
It does look like something's different from M15.
I've only got Prime Express, which doesn't evaluate symbolics. Have you tried explicitly defining xi to be a 3-vector?
Stuart
Your worksheet did not work for me either.
I recreated it in MC15, converted it to Prime and now we have the correct results.
I could not spot a difference.
I went same route of re-creating in 15.
- looks like another candidate from the mathcad mad-house.
Problem is with the first ξ in the Jacobian.
Regards
Andy
Werner_E25-Diamond IAnswer
WE
Of course. Keep on forgetting MP's little oddity there.
Nice to know why it fails
Andy
PTC's introduction of labeling in prime is too troublesome....It was a good intention but often come out to be useless. I think they must add a reminder to user when ever the exact same 'name' has two different labelling. Math ad prime sometimes automatically choose different label for the same name and it is causing a headache to me.
thank WE very much for finding the glitch
Have a new question about the same worksheet.
This is more related to mathcad usage
Would like to solve x_greek[1, [2, [3, in terms of x[1, [2 and [3
or simply x_greek in terms of the component of x
I know how to do it without using index (I.E. using x_1 instead of x[1 )..
but if I do want to use it this way, what can I do? Because I do not want to type/copy and paste the equation again
At first glance I thought the problem was the boolean equal sign but correcting it didn't solve the problem. Clueless!
So Mathcad 15 does not allow programming nested aray? Thank for any answer in advance.
23-Emerald V
January 27, 2013
es un aparato inteligente que te ayuda mas en tu mente
