K Value in a VERTICAL CURVE
Chasethewind-di
Example:
G1 = 2.5%
G2 = 1.5%
Length (L) = 100 Ft. or whatever.
So it will be a CREST Vertical Curve.
1. How do we calculate the Algabraic(A)Difference in grades? Is it just 1.0%? And what is a algabraic difference? Can there be a negative Algabraic Difference.
2. K = L/A Is this the Correct Formula?
Thanks.
You questions may be answered by a search of the internet. I went to Altavista and entered the following as search criteria:
K-Value Vertical Curve
Clicking the "Find" button produced 722 hits.
The third one (or maybe the second, depending on how one counts hits) seemed particularly interesting. I repeat it's link here for your convenience:
http://kepler.covenant.edu/~swanson/pdf/verticalcurve.pdf
FYI Everyone
Example
G1 = -1%
G2 = 3%
So the algebraic difference = 4%
The formula is also correct.
Remember you NEVER can have a negative algebraic difference.
Thanks anyways Peeps.
Found it in an old surveying book.
